Hello, I am prepared to encode the finished video clips (.AVI) to .mpg to author on a dvd.
I am using TMPGEnc DVD Source Creator to do the encoding. The software is asking me if I want to
Encode all clip into one single MPEG file.
or
Encode each clip separatedly to MPEG files.
Which one should I choose to make a life little easier and why? Thanks in advance.
Hi iKwak,
If all the AVIs are going to end up as one continuous bit of footage, then encode to one single MPEG clip.
If each AVI is it's own bit of footage (like different holdiays) and it'll be in it's own track on the DVD, then encode each clip separately.
A track could contain, say, your winter holiday while another track could contain your summer holiday. So each track has it's own "movie" (or whatever) in.
Each track can then have it's own chapters - sections within the "movie".There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
What Daamon said, but remember that if you do multiple files into one at the encoding stage, it may well be notciable where the joins are. Conversely, if you output to separate files and then use your authoring software to join them, you may experience a slight pause between clips.
If in doubt, Google it.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
