Has anyone tried to rip A Knights Tale? I am using Smart Ripper and it starts to work then at 18% it just stops. I have never had a problem before with any other DVD. Does this title have something on it that prevents it from being ripped. Another thing I found strange was that the 1st file it rips is labeled VTS_03_01 (vob file). Any other titles I have ripped always started vts_01_01.
The VTS_03_01 may be your first clue. Is it a multiangle DVD or something else abnormal? What is the length of the title you're trying to rip? You might try selecting a different title in Smartripper.
it doesn't matter which vts_XX is stored at..it could be at like vts_69 if it wanted to, but that has happened to me before and it is most likely because your DVD disc bottom is dirty or scratched..try cleaning it CAREFULLY and try again...should solve problem
ashtones, I don't have or tried to rip the movie, i'm here just to give ideas, have you tried using Sector Extractor ? i find that when it comes to stubborn movies, this little thing ripps anything in it's way
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Scan lines in the rip.....any help would be good
By Spinal_Core in forum DVD RippingReplies: 11Last Post: 27th Aug 2011, 12:57 -
Is AAC 48.0 KHz good audio for a bluray rip?
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 5th Jun 2010, 18:18 -
Trying to rip DVD's...... quality is not good.... sugggestions?
By True Colors in forum DVD RippingReplies: 6Last Post: 29th Jan 2010, 10:24 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28
