Hi guys,
I am a little stumped trying to edit a vro - i have tried TMPEG Mpg editor, but when i output the file after editing and import it into DVD author, it moans about GOP lenth.
I just want to be able to edit the VRO frame by frame, and output it (chop it) without having to re-encode, as there is no need for that...
Any ideas what i should use...funny thin is, i used to use TMPG-VCR to do this, and it worked fine, but it then just stopped working, and started asking me what bitrate i wanted etc when outputting.
Please any ideas would be great...remember i dont want to re-encode, just chop out crap i dont want, albeit frame perfect and then output the .vro again edited (vro's go fine into TMPGE DVD author)
Editing Panasonic Burner DVD-RAM VRO Video In Computer
By Teshia in forum User guidesReplies: 47Last Post: 18th Feb 2013, 08:06 -
Need To Split A DVD-RW .VRO File
By 360Spider in forum DVD RippingReplies: 2Last Post: 21st Jun 2010, 11:55 -
VRO file (VideoCAm) to DVD degrade the video ?
By c1steady in forum Video ConversionReplies: 0Last Post: 28th Apr 2010, 03:08 -
how do you convert a vob file into a vro file?
By johnsteed in forum Video ConversionReplies: 29Last Post: 13th Sep 2007, 07:12 -
Extracting .VRO file from DVD-RAM to pc for editing
By mattsz in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2007, 13:25
