Dear Forum,
I know this question is asked all of the time, but I can't find the simple way to accomplish my task. I'm trying to rip audio (maybe movie quotes or songs) to .mp3 from a DVD. So I...
1. Rip the DVD with DVDDecrypter. This usually doesn't take to long and I'm satisfied with the .VOB Results.
I like to use Adobe Audition to manipulate the sound file because I can save straight to .mp3 and cut/slice exactly what I need. It also shows the video playing with my sound file. Question, is there a good program to take the .VOB into and .AVI or .MPG in some TIMELY way. Will renaming hte .VOB to .MPG affect the quality at all? When I do this, it takes a LONG time to import the audio from video into Audition. Any help would be appreciated. Thanks.
Hi kouchimk,
VirtualDubMod accepts VOBs and MPEGs as input files. From there, I believe you'll be able to extract the audio - either direct to MP3 (not sure, as you'll need an encoder like LAME) or to WAV (definitely).
And WAV to MP3 is a breeze...
Hope that helps...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hello,
In the tools shortcut found on the left of the screen <---- you'll find a section of dvd rip tools. Here are 3 dvd audio rip tools:
https://www.videohelp.com/tools?tool=1_DVD_Audio_Ripper
https://www.videohelp.com/tools?tool=DVD_Audio_Extractor
https://www.videohelp.com/tools?tool=ImToo_DVD_Audio_Ripper
Another option is to use dvd decrypter in stream processing mode and rip the ac3 file from the dvd. Then using besweet (with the besweet gui as it is a command line tool) you can convert the ac3 to mp3/wav/mp2 and a host of other options.
If its a concert dvd you can rip in chapter mode in dvd decrypter and then convert each ac3 in batch mode to your desired format.
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Extract Audio and video from Multiplex karaoke DVD and re author
By quebecLA in forum Video ConversionReplies: 1Last Post: 8th Jul 2011, 22:01 -
Need simple software to extract video portions from .avi movies
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2011, 11:01 -
Extract Audio from XviD MPEG-4 video
By MI6 in forum AudioReplies: 2Last Post: 3rd Jan 2009, 05:58 -
Any 1Click Blu-ray / HD-DVD method to extract selected Video/Audio streams?
By jmone in forum DVD RippingReplies: 3Last Post: 2nd Jan 2008, 10:12 -
how do I extract audio from mov mpeg-4 video in Ubuntu Gutsy?
By hurtstotalktoyou in forum LinuxReplies: 2Last Post: 25th Dec 2007, 03:50
