Page 2 of 2
FirstFirst 1 2
Results 31 to 33 of 33
  1. Member Super Warrior's Avatar
    Originally Posted by stiltman
    Tell you the truth, I can't remember exactly how I did it I just knew that it work on about the 5 -6 try. Like I said, it was one of the hardest things I'd ever done with a DVD structure.
    However, I guess I should of taken the quick trip around and just posted the question here On the other hand, I at least I learned how to do it, even though I prolly couldn't repeat how I did it. Thanks to you! I don't have too now
    Pretty sure I did it by your first method. I remember doing the hit and miss with which one to copy for the 3rd DVD. BTW, this was all for the winsor pilates DVDs which I know she'll never watch and do all three in a row like she says she will
    I have another question about DVDRemakePro. Which menu holds higher priorty,DVDremake's start up or the title's menu?
    Inotherwords if i'm watching 1 of the 2 DVDs joined to one disk, and i hit the button to get back to the menu, which will it do?
    Will it go back to the menu on the title i was watching, or will it jump all the way back to DVDremake's startup menu showing the option of which disk i want to view?
  2. It will jump back to the root menu (1 of the 2 DVDs which joined to 1 disc) However, if you want to go back to the title menu which gives you the choice of watching disk 1 or 2, you have to press the title menu button on the DVD player remote control or DVD menu on some other players (As I know so far, some DVD player remote control does have 2 menu buttons: 1 for root menu, 1 for title menu)
  3. And one more think. How to make just a menu with GUI For DVDAuthor? I placed three text labels on the vackground, and what then?
    Millan
