I rencently had a fiasco with DirectX screwing up my system and halfway got it fixed...I just encoded a DVD NTSC mpg clip in Vegas and the audio does not play, but I know it's there because it is showing an audio stream in VirtualDub, that and it plays on a diff computer,,, can someone help me to get computer to be able to play mpg audio again, it does the same thing for mp3 files =(
Results 1 to 13 of 13
Hello,
Please don't bump your post without waiting a copule of days. This isn't a chat room.
well I took your advice and got this Gspot program, no such luck, it just shows n.a. for everything,, I already know that it's mpeg audio that isn't working, like I said, I rendered a clip in Vegas which uses the Main Concept encoder, I made a standard mpg 2 file, video is working, but the audio is not....
But it did help you. By saying na (not available) it
is showing you what is missing. Sounds like
you need to start off with a new copy of MS Media
Player
http://www.microsoft.com/windows/windowsmedia/download/default.asp
..and a codec pack like
http://home.hccnet.nl/h.edskes/finalbuilds.htm#klcodec -
that codec pack didn't fix it
i have the latest media player tooo
Ok, now try downloading a demo copy of
powerdvd and installing it.
http://www.gocyberlink.com/english/download/dl_file_new.jsp?dl_id=213&ProdId=1
This should fix any remaining directshow problems.
If not, then the issue may lie elsewhere -> soundcard etc.
Try this and get back to us. -
ps: you did renew your copy of msplayer?
Can you hear music audio? Do DVD's play ok with audio? -
what do you mean by " renew your copy of msplayer" do you mean reinstall?
MP3 files play in media player, but they don't play in BS Player,, I will have to check on playing DVDs,, but then again, my DVDs are AC3 audio, not MPEG Audio, so it doesn't seem like that would tell me anything... -
I don't understand ? What audio works and what
does not? Are you saying AC3 works and mpeg does
not? -
that's correct, no mpeg audio seems to be workin,,, and now avi audio isn't working either!!
Right now I'd suggest a system restore if you have
restore running. There are too many variables now
if you have already tried what I suggested in full.
What exactly was the "fiasco with DirectX" you
experienced?
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
WMV/MPG problems
By Metallian MetalGod in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2008, 21:35 -
Having problems with MPG-HD to MKV
By SpydaMan in forum Video ConversionReplies: 10Last Post: 25th Mar 2008, 21:37 -
Newbie problems: TS to Mpg conversion
By waehuun in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2008, 16:00
