    Jan 2004
    huntersvile, nc
    hey guys,
    is there a way in dvd lab pro, to make it so that a button is invisible but it will activate after a motion menu plays it's duration (4m 30s)?
    thanks,
    schunn99
  2. if you would like the motion menu to keep playing once the button has appeared then why not just have 2 clips, one without the button and one with the buttons, set first play to the clip without the button then link the end of that to your motion menu with the button ..... that should work
    or if you mean you want your motion thing to play then the menu buttons to appear at the end and NOT for the motion to continue then the only way if found to get arround this is to create a menu with the last frame of the clip as the background put all your buttons and stuff on it so its just a static menu, add your INTRO clip as a movie and make it first play in conections and then link from the clip to the menu ....
    that was my best guess to get it working, although im still learning this stuff myself ive managed to get this to work quite well, you can even add a fade in to the end of your clip to have your buttons fade into view at the end of the clip, take a lot of time and patience to get that right though
  3. DVVD-Lab pro has a delay button for motion menus. Look at the video bar directly underneath the motion menu. There is a slider on the video bar that will allow you to set the duration of the motion menu and play before the buttons show up.
