hey guys,
does anyone know how to convert whatever format that itunes is in, to wma or mp3? I think the format is quicktime 'cause that the only player that will play it.
thanks,
schunn99
I think you have to burn them to CD, then rip them back to the PC into Mp3..I maybe wrong..
Hello,Originally Posted by canadateck
Nope that's the best way to do it my opinion. Use rewritable cdrw's unless you want to use a cdr with the songs on them
It is a drm coated aac file.Originally Posted by schunn99
You need to burn it to a cd then rip it to a wav file.
From there you can convert it to whatever format you want. -
This is true - I've just done it.
I have not tried it yet, but this is supposed to work on the machine on which your iTunes track is authorized.
http://hymn-project.org/
Note that this is ONLY meant to allow you, the legitimate user, to play your track on whatever hardware you want. Don't use it to create warez! Not only is it illegal, but the utility purposely leaves your iTunes ID embedded in the file to discourage improper use.
How to add an iTunes .mp4 song to my video with VirtualDub 1.9.9
By mileena in forum Newbie / General discussionsReplies: 6Last Post: 27th Aug 2010, 13:36 -
Which would you buy: the Amazon MP3 or iTunes version of a song?
By sldvd in forum AudioReplies: 8Last Post: 12th May 2010, 21:48 -
Pigs can fly - itunes song plays on my zune without converting!!
By yoda313 in forum Off topicReplies: 2Last Post: 19th Jul 2009, 12:42 -
Gray "!" iTunes 8 annoying song location issue...
By Nintendo Fan in forum ComputerReplies: 12Last Post: 14th Jun 2009, 10:38 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 00:17
