hey guys
quick question: How do you make a motion menu so that after the video finishes playing it ends up on the first frame of the video and all the buttons "Magically" appear?
thanks,
schunn99
You need to use an editor or similar program to create the menus and fade in of the buttons first (After Effects is good for this is you need effects, otherwise any editing software will do). Then in DVD Lab create the sub pictures for the buttons (the bits that get highlighted) and set a delay to match the fade in of your clip.
Read my blog here.
Vegas to DVD Lab Pro motion menu issues
By outerspacerace in forum Authoring (DVD)Replies: 4Last Post: 23rd Jun 2008, 21:28 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 08:32 -
Delayed Links, Motion Menu and DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 14Last Post: 30th Apr 2008, 02:33 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 13:03 -
how to make motion menu in dvd-lab pro that like this
By 741210 in forum Authoring (DVD)Replies: 10Last Post: 23rd Aug 2007, 23:53
