Hi, I was wondering if I had a 650MB mpg and the length was 90 mins, and I was using a 80 min 700mb disc, if I could burn the movie on one disc. Instead of using two. For VCD btw. Or perhaps burn 74 mins and 800mb with a 80 min 700mb disc. Thanks.
Verbatim Data Life Plus 80 min 700 MB (to be exact)
If the MPEG itself is only 650 MB, it will fit on any size disc. You could even burn it as a data disc on a 74 min CD. If you burn in VCD/SVCD (mode2), you can fit up to 740 MB on a 74 min disc. It's data size, not playing time that matters. If it is 90 min. long but only 650 MB, it isn't VCD compliant, however.
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
VIDEO_TS on a CDR?
By kippard in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 05:20 -
.cdr on a DVD+ needs to be converted
By jamesmarcustucker in forum Video ConversionReplies: 20Last Post: 8th Sep 2007, 15:40 -
CDR TO DVD software please
By Lennoxtown in forum Authoring (VCD/SVCD)Replies: 5Last Post: 7th Aug 2007, 12:04 -
DVD Media... NO CDR!
By Lighters in forum MediaReplies: 5Last Post: 5th Jun 2007, 11:26
