Hi all!
Just bought a tv-card and started to transfer from vhs to dvd everything works fine. I capture with VirtualVCR and encode with Tmpgenc 3 Express.
The problem is when i´m done it looks good on the tv but it looks bad on my computer, why?
Hope someone can explain why!
/Jonas
Results 1 to 10 of 10
Originally Posted by Myran79
Tv needs interlaced, computer does not. -
If you're playing it on the PC, then "non-interlaced". If you're playing it on a TV, then "interlaced".
If your source is interlaced, and you intend to watch it on a TV, leave it interlaced. De-interlacing will only introduce artefacts and reduce quality.
If your source is progressive, leave it that way. -
Quoting a passage from The Bible:
Technically, DVD-Video can only be stored in interlaced format. Signals from standard video cameras are already in interlaced format. Film, which is inherently progressive, is encoded into MPEG-2 as paired fields. Even though the encoding is field-based, the frame-based nature of the source can be preserved. This allows progressive scan players to put Humpty Dumpty back together again.
HTH"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Hi Guys! I´m back!
This is how it looks, i can´t imagen that the difference should be this bad.
This is from my avi that is captured with VirtualVCR
And this is what it looks like when i encode it
I encode with Tmpgenc 3, no filters.
What is the problem?
Hope someone can help me?
/Jonas
Which camcorder (newbie question)
By CliveJ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 32Last Post: 19th Aug 2011, 12:36 -
Newbie codec question
By fotoruss in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 21:47 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 22:25 -
Newbie Divx question
By Contact in forum Newbie / General discussionsReplies: 13Last Post: 13th Apr 2009, 10:57 -
Newbie Networking question
By karl333 in forum ComputerReplies: 1Last Post: 5th Mar 2008, 12:23
