Almost all of my Mpeg2s are from a sources that encode with "top field first." Of course, one program (Proshow) encodes "bottom field first." This is causing me problems when I try to include that output with others in my NLE.
Does anyone know of a way to re-encode an existing file to "top field first" without creating flutter around motion?
Correct me if I am wrong, but using either of those two programs would just simply change the field order, but not the video. Seems like one would have to split the fields, add a blank field to the beginning, then re-weave them. And then change the field order. An AVIsynth script should do the trick.
Darryl -
I talked to the author of Restream. He says that his program just changes the flag (for when it's set wrong) and would not actually fix the encoding in the file.Originally Posted by upshot
I'll give PullDown a shot but the page says it can be used to "modify most of the relevant MPEG-2 flags" which makes me think it's the same kind of tool.
I don't want to just modify the flag. I need to change it to a true "top field" file so it will mix well with other files. -
any high quality NLE can handle both TFF and BFF in the same project ...
that is - any HIGH quality NLE,
if you have it -- procoder can swap (truly change - not just the flag) the fields , so can TMPGENC (and save to avi)
also there are filters for avsynth and v-dub"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
"Hide" field locked in Subtitle Workshop
By neuroxik in forum SubtitleReplies: 0Last Post: 17th Aug 2011, 03:08 -
MediaInfo field "Duration_LastFrame", meaning?
By Gew in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2010, 18:22 -
Setting "top field first" flag without re-encoding/re-authoring
By Miles in forum Authoring (DVD)Replies: 2Last Post: 16th Jan 2009, 07:15 -
Seeking avisynth function for "blend-a-field" idea
By vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 21:52 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 6th Dec 2007, 00:19
