ive been trying to caoture vhs both to my liteon 5001 dvd recorder and my happauge wintv card on my pc but im getting problems with the video rolling upwards when i start my vhs tape. the vid rolls up a little then stays there as if the vertical hold is out, any ideas how i get round this? thanx
Results 1 to 10 of 10
I don't think VHS players have a vertical hold.
Does this happen on all tapes ?
Does it happen when playing a tape to a TV ?
If it happens on all TVs and all tapes, I'd suggest some sort of mechanical issue with the heads on the VCR. Are these commercial tapes ? It could be macrovision, although you usually also have colour issues and image bends.Read my blog here.
tks for ur reply guns1inger. no i dont have a vertical hold on my vcr but i was thinkin its macrovision tho like you say i dont get any image bending etc.
if i stop the tape and restart it, the "split screen" moves so eventually i can get it to stop at the bottom of the screen but its not ideal and very occasionally it'll start to move again during the course of the recording process...very annoying. its a new vcr, hardly ever been used and this doesnt happen during normal playback only when i hook it up to my pc or dvdrecorder. uis there any software i can use to fix this? -
If it's macrovision (and it's starting to sound like it is) you need to run the signal through a full frame timebase corrector or signal amplifier that can strip the macrovision out.
I use a TBC-1000, but this may be overkill for what you need. If you are handy with a soldering iron, you could try here
http://www.repairfaq.org/filipg/LINK/F_MacroVision3.html
Otherwise, this might be OK
http://www.videoguys.com/sima.htmRead my blog here.
It sounds more like a tracking issue
But it could be MV. A TBC would probably clean it up. -
This sounds like Macrovision....
TBC is neccessary in this caseLa Linea by Osvaldo Cavandoli
tks for the reply guys, im thinknin macrovision as well. oh well ill have to think up somethin else to do lol
Get a Video Stabilizer, that should work. Its a Cheap solution!
vhs with vertical lines
By spiritgumm in forum Video ConversionReplies: 29Last Post: 22nd Aug 2019, 09:17 -
VHS-C : Can TBC correct lost vertical sync on recording start?
By cym in forum Capturing and VCRReplies: 4Last Post: 24th May 2010, 07:54 -
VHS to DVD - LongPlay VHS Problem
By zanzi81 in forum Capturing and VCRReplies: 14Last Post: 1st Feb 2010, 01:56 -
Irritating problem (flashing vertical bars)
By weko in forum Newbie / General discussionsReplies: 5Last Post: 30th May 2008, 06:40 -
Vertical hold problem with Majix PhotoStory 5
By pdvdr in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2007, 11:10
