  1. hi everyone, im wanting to know how to converet this movie into a iso file, the movie is (shaun of the dead video-ts.bup.) thanks
  2. DVDDecrypter will do this for you
  3. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    John, if you want a one step conversion to .iso ready to burn onto a DVD-+R.. DVDShrink will do this. Or DVD Decrypter will give you the full .iso, and from there you can load into shrink, dvd2one etc..or any other shrinking program you like...then use IMG Tool Burn if your shrinking program of choice dosnt output .iso's etc...imgtoolburn will make your Video_TS folder into a .nrg.
    :star: :star: :star: :star:
    Archived DVD Scans
    Nero V ImgTools V Decrypter
  4. i have the file sitting on my desktop i cant get the file converted into a image file
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What type of file is that ?
    If in doubt, Google it.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    An iso is a container, like a bucket - you can put anything (like water) into the bucket/iso but you can't convert the water into a bucket.
    That said, ISOs (containing anything) are easy to create with imgtools classic
    /Mats
    can i put a hole in the bucket?
    8)
    sorry it's waaaay too dead at work today :P
    Apr 2003
    Largo, FL
    Do you have all the files (vob, ifo, bup) on your desktop (or in a folder on your desktop)? If all you have is one file- video-ts.bup then you're missing 4-8 Gig of files.
    If you have all the movie files then (as said above) you can open those files and make an iso with DVDShrink.
