Cable boxes with built-in DVR's from comcast (Motorolla 6208) have a working firewire feed. There was actually a regulation by the FCC saying the cable companines can not block the port.
On the other hand, they also have to pass copy protection flags in the stream at the request of the station/producer, etc.
Right now I am able to capture most of the HD-Digital content out there. Moive Channels are generally blocked, but if you wanted to capture a HD recording of a typical network broadcast show, or sporting event you shouldn't have a problem through the 1394 ports.
Results 31 to 33 of 33
what about pci dvb cards?
add a cam module and bam, you got all of your shows on your computer in mpeg2 format
I got haupauge nexus-s I record tons of FTA of Telstar5 satelite
As I said you can use exact same PCI card with cam module and dishnetwork smartcard (from your receiver) and you get all channels on your computer
No flags, record as much as you want -
Over at AVSForum there was a discussion of a software-emulated Digital VCR which would work on the PC thru the firewire connection from a cable box. Also a company listed, whose name I forget, which made a box for around $400 which sat between a satellite box and the PC. Not sure exactly what it did.
It would seem that if the firewire port will output to a Digital VCR, and if such a VCR can be emulated in software, this would be the way to go. It was said that full Hi-Def picture was indeed captured.
scientific atlanta cable box explorer 2000
By Darkcast in forum DVB / IPTVReplies: 1Last Post: 13th Mar 2011, 14:49 -
scintific atlanta 2200 cable box
By bammthis in forum Capturing and VCRReplies: 8Last Post: 16th Mar 2010, 01:32 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21 -
Scientific Atlanta HD Cable Box / HDMI Audio Problem
By culttvguy in forum DVB / IPTVReplies: 5Last Post: 14th Sep 2008, 16:48 -
Scientific Atlanta 8300 HD/PVR Rogers Cable Recoding Required To Work.
By musicmavern in forum DVD & Blu-ray RecordersReplies: 6Last Post: 8th Aug 2008, 12:52
