Hi, I am looking for some MPEG tools that can cut bad frames from MPEG files..
I have some MPEG I want to burn on DVD.. I would first use TMPGEnc to reencode to MPEG2 format.. but if there is a bad frame.. TMEGEnc will not work.. tried to use TMPGEnc Cut/Merge Tools to "take" bad frames away.. but not work... it won't move any further once it sees a bad frames...
someone here suggests me to try VideoRedo.. I tried the current version, it said a "Non-Linear Mpeg tools".. it works great.. only problem is that.. it is expensive .. $50 US..
any other tools that can do the same thing? is that true that I have to look for "Non-Linear Mpeg tools" only? I tried older VideoReDo, which is not Non-Linear version, it doesn't work...
thanks
Try any of these here:
https://www.videohelp.com/tools?s=12#12
I've never had to use any of them as I've never come across any bad frames in all my encoding. (Gee, I never realized that before.)
Also be sure it's a bad video frame and not a bad audio frame. If it's audio it will still refuse to open with tmpgenc mpg cutter/joiner. -
cutting frames out of mpeg will require some re-encoding ..
you cant just take out a B or P frame or I frame and think everything going to be alright .
timestamps will be messed up also --
best to re-encode it all"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
decoding mpeg video into frames say I,P,B frames
By abeer in forum ProgrammingReplies: 44Last Post: 6th Oct 2012, 08:24 -
Any tools for copying / reading bad quality discs?
By Locut0s in forum DVD RippingReplies: 2Last Post: 12th Nov 2010, 08:06 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 21:57 -
What's the deal w/people leaving tools bad reviews for false virus positive
By freebird73717 in forum FeedbackReplies: 4Last Post: 13th Jan 2010, 20:53
