I've got an audio file which looks like an image file. There is a cue file and a file that ends in .mpc. I tried burning it with Alcohol 120% and everything seemed to work fine but when I played the Cd there was nothing but static. Is there a way to burn or convert this file?
www.rarewares.org/mpc.html
I dont know what it is but it must be converted to be burned. -
mpc = musepack. Decode the mpc to wav, then edit the cue so that it points to the wav file and has WAVE instead of mpc or whatever it has now.
It should then burn fine with Alcohol, you can however test it by mounting the cue.
MPC+CoreAVC
By quzma in forum Software PlayingReplies: 0Last Post: 1st Jan 2012, 16:51 -
Mpc-hc
By Silldog in forum Software PlayingReplies: 2Last Post: 23rd May 2010, 10:39 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
mpc-hc won't play certain vids mpc will?
By aedipuss in forum Newbie / General discussionsReplies: 2Last Post: 29th Aug 2009, 21:41 -
EVR via MPC
By ckamc in forum Software PlayingReplies: 0Last Post: 23rd Apr 2008, 22:48
