I have recorded some standard definition dtv and it converts to dvd easily enough, only trouble is at the top edge of the 16:9 picture on a computer monitor is some light lines of noise.
I can mask that with TMPGENC but I don't want to have to reencode with TMPGENC.
Does anyone know any tools that can take an already dvd compliant mpg and allow masking to cover over such problems as this without having to reencode?
I believe when you author the MPEG to DVD those lines of noise will be cropped off. I do alot of VHS--->DVD conversions and I see the same distortions at the edges when I get my AVI, but when i author the MPEG and watch it on my set top, they're cropped out.
joecav...I think is right,it may/99.9999% of the time be gone when you Author.
Thanks for the replies guys.
The noise actually appears between the 16:9 image top and the black band of the letterbox on the 4:3 monitor.
When I have authored it is still there, but if I had a 19:9 TV it would be at the extreme top of the screen or maybe drop off like the VHS noise does at the bottom of a 4:3 TV.
Jagged Edge Of Video Picture
By kenryuakuma in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2011, 07:24 -
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 19:42 -
Captured video has pixel noise on top edge of display
By cohoman in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2008, 18:32 -
vegas picture in picture and masking
By wingfan in forum Newbie / General discussionsReplies: 0Last Post: 16th Jul 2007, 19:40 -
Edge artifacts noise caused by transitions/dissolve effects.
By baculus in forum EditingReplies: 6Last Post: 25th Jun 2007, 17:07
