Closed Thread
Results 1 to 25 of 25
    Jun 2004
    Ferrara-Italia
    man! does there need to be a guide for converting uncompressed audio to mp3?
    Sorry, I had to go see about a girl
  2. for 1:1, of course man.
  3. Member daamon's Avatar
    Melbourne, Oz
    @ LordVader - I think, on this one, the force has left you...
    Do a search in Google for "WAV to MP3" and pick one of the many returns.
    There's software galore where you load up your WAV and hit "Go" to get an MP3 out in the designated location.
    I use MusicMatch Jukebox.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  4. dammon, i joined vcdhelp on 2001, and i have less posts than you, you know what that means ?
    that most of my problems, have being solved by my self. so let's try to respect each other.
    when i did my first search in google, your mom were still on dyper.
    i'm not asking just for ask. Read my question again.
  5. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    is it possible to get a 1:1 copy from WAV to MP3,
    even if you use a high bitrate it still wouldnt be 1:1
  6. daamon
    do you know, what LAME is ?
    do you know, what High frequencys are?
    have you ever used command lines, in a software by DOS ?
    i guess not. cause babys always use GUIs. that's why you love MusicMatch
    don't take it personal , just fuc#in' with you, man.
    Sifaga
    there was a contest time ago about mp3 encoding, where some judges couldn't tell wich one was the Mp3 and wich track was the RAW version.
    do a search on the net. all the articles were related with LAME encoder.
    like you said, is impossible to get 1:1 encoding, but there's always some tips to archive resolutions and preserve that at the cost of less space.
    that's the kind of information that i'm looking for.
    canada
    Also means you dont help much either,all you can do is set to the highest bitrate the program will let you set which is usually 448kbps or near their.
  8. Member daamon's Avatar
    Melbourne, Oz
    An interesting interpretation. I would've read it as "you only post when you have troubles and don't contribute by helping others"... If you bothered to look at the vast majority of my posts, they are attempts to help people.
    Google wasn't around in the 40s... Oh, sorry, was that some lame attempt at either being funny or offensive? Sorry, I don't get simple American humour. Apart from the one where George W Bush got elected, then re-elected. Now that speaks volumes...
    I wasn't answering with a view to belittle. Chill. I was trying to help whilst injecting a little humour. Hence the line "the force has left you".
    Now, if I've misunderstood your question (which is entirely possible - we're all human) then either point out my mistake politley (including spelling my name properly please) or by phrasing your question better.
    Carpe diem.
  9. <----- does this face look funny or offensive ?
    that's great man, you need glasses too.
    of, ok, let's focus. I don't wanna start a discussion here.
  10. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    For 1:1 look for a "lossless" codec. MP3 isn't one.
  11. Another troll. great.
  12. Member daamon's Avatar
    Melbourne, Oz
    daamon
    Yes.
    Yes.
    Yes.
    No, I use MusicMatch coz it's quick and easy. I use DOS commands on the rare occassion it's quicker and / or easier.
    Too late.
    Do you know how to use punctuation correctly?
    Do you know how to spell "frequencies" correctly?
    Do you know that you should start sentences with capital letters?
    Do you know that by throwing insults around that you're less likely to elicit (that means "get") help from people - not just the one you're trying to insult, by also others who see how petty you are?
    Do you know that if you're just ******* with someone, it's best to end in a so they know?
    Carpe diem.
  13. is not fair daamon , i'm not talking about your bad spanish here ok.
    so don't metion it
  14. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    WAV is 1536kbps. MP3 can't be done @ 1536kbps - I use CDEX and it stops at 320kbps. Therefore 1:1 ain't possible AFAIK.
    Last time I checked, free help was good help too
    If in doubt, Google it.
  15. do you know anything about the preset used for the albums you find on the net ?
    is VBR, not 1:1, but when center channel is removed, it sounds really great.
    Dec 2004
    Australia
    The max bitrate of mp3 is 320k, I would suggest that you head over to hydrogenaudio and do some reading.
    Also I am not to sure that you can read anything much into posts/days joined. According to you I have needed a lot of help (high posts/days ratio) and haven't been finding answers on my own when in reality I haven't required any help.
  17. you're right. i shouldn't post anything.
    maybe i was a little bored you know, and tired of looking into some other stuffs.
    thanks anyway, have fun
  18. A-B listening tests show that MP3 at 320 kbit/s is transparent to the source audio.
    I personally recommend using the r3mix preset on LAME. Relatively good compression, essentially transparent audio. The settings are mostly logically deduced.
    Regards.
    Michael Tam
    w: Morsels of Evidence
    Dec 2004
    Australia
    r3mix? You are joking right?
  20. So you think that you can hear the difference between r3mix and source audio?
    Regards.
    Michael Tam
  21. Banned
    Sep 2004
    Inner Circle of Thought
    Uh, no
    That is a very dumbass thing to say.
    You're right. I shouldn't post anything.
    Then why do you do so and make yourself look like a moron?
    You should not be so insulting to the people that you want help from.
    Some of the smartest people prefer GUI's.
    You know why, because the more operating systems you mess with, the more you have to remember.
    There is nothing wrong with musicmatch.
    I use it too.
    You can not do a 1:1 copy for the obvious reason.
    You are working with a compressed file that gets rid of the higher frequencies.
    End of Rant.
  22. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    DON'T GO THERE ... THIS COMMENT REALLY PISSES ME OFF ... Why don't you take this comment to some political board and keep it out of this site!!! How's that for American humor!
  23. Video Restorer lordsmurf's Avatar
    This thread has been worthless since the first post.
    Locked.
    - If you want a guide, make it.
    - If you have a specific question on how to do something, ask it.
    - If you want to talk politics, go elsewhere.
    - If you want to argue, go elsewhere.
