Hi, a friend brought over a dvd in .iso form. I burned it and tried playing it in my dvd player and it says this disc doesn't match this tv format type. But i can play it in a region free dvd player fine.
Does anyone know how to take this .iso file and make it region free. I want to be able to watch it in my regular dvd player. I just can't seem to make the .iso file region free. I also extracted the .ts folder of out the .iso file but still can't see how to make it region free. Dvd shrink won't even load the TS folder.
Any Ideas!!
Results 1 to 11 of 11
Hello,
Have you tried dvd decrypter??? It handles iso.
Also - is there a chance it's a pal disc (Europe and other countries)??? If so then you'll have to do the pal-ntsc conversion. Just a thought.
yes, my mistake I believe it is a Pal and i need to go to Ntsc. Anyone know of any free good converters out there??
Thanks again guys!! -
Do you know how much qualitywe are talking about here? I will try one and watch it and see if I notice much difference.
Thanks guys for all the input!! -
I just did one PAL to NTSC using TMPGEnc Xpress
3 and let it run overnight....2 Pass. I already had licensed the AC3 plug-in so It was auto recognized and use.
I selected to use the DVD files I had already ripped to the hard drive ended up with 1 big mpg with AC3 sound that I added to TMPGEnc DVD Author 2 times as it was a dual episode DVD. Trimming off the parts to end up with two discrete episodes on thge menu, Then I Trimmed out a dance number as a motion background for the menu.
It took a fair time probably because of the AC3 audio and 2 pass encode?
Easy to use. I just selected output size to fit a DVD 4.7Gb. That option auto sets Bitrate.
I just started another one that is an almost 3 hours long movie before coming to work today. It started out showing 13.5 hours to finish but that was already dropping down before I turned of the monitor.
System P4 3.0Ghz 1Gb Dual Channel DDR so my machine is not a real slow machine. Reading from 1 drive and outputting to another too.
Output quality looked good on the computer and I'll be looking at it tonight on the TV
I chose this program so That I could work from the DVD rip directly into the program and back out as AC3 to convert those PAL format DVDs to NTSC DVDs.
3 steps
DVDDecrypter
TMPGEnc Xpress
TMPGEnc DVD Author, Burn direct or Nero
Quality before speed! YMMV however.
Cheers
Hack working for Sony BDP-S380 region 1, to make it region free?
By Julieso in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Dec 2011, 16:12 -
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Burning files to Change the Region!?
By PhyRo in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Oct 2007, 09:30 -
Yamaha DVD w/HDMI remote hack? Region 1 to all region [PAL]?
By eurocd in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Jul 2007, 12:58 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 21:35
