Hello,
Ok I'm still hunting for a new 3d card (PCI only not express). My target range is near $100 (us).
I've done some more digging and here are a few cards that I've bumped into (the AGP models are for reference only - if anyone knows if a pci version is available I'd be interested).
http://www.bestbuy.com/site/olspage.jsp?id=1093469970538&skuId=6880459&productCategory...1&type=product
Radeon 9550 128mb vision tek - bestbuy $100 - AGP though
VTK9550128AGP
128MB DDR memory; AGP interface; VGA, DVI-I and TV outputs; 250MHz core clock speed
http://www.bestbuy.com/site/olspage.jsp?id=1091099665137&skuId=6727143&productCategory...1&type=product
Geforce fx 5500 oc (bfg) - $100 Agp thoughBFGR5500OC
128MB DDR memory; AGP interface; VGA and S-video outputs; 290MHz core clock
http://www.bestbuy.com/site/olspage.jsp?id=1091099665193&skuId=6731799&type=product
VCGFX55PPB
PNY GeForce FX 5500
128MB DDR memory; PCI interface; VGA and S-video outputs; 270MHz clock speed $120
I think $120 is the MAX that I'd go. Though I'd like to keep it at or below $100. I'll be happy with 128mb DDR if it's a new enough model that won't be obsolete in a year.
Nvidia or ATI doesn't matter - though I want it to be one of those big guys. The board manufacturer doesn't matter to me - just the chip in it.
Thanks for all suggestions. And I do appreciate the help and advice I've received in the other threads for their help too.
Kevin
Why not use AGP???? I thought you just bought a new rig so a slot should be there....
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
Hello,Originally Posted by makntraks
It doesn't HAVE AGP!
That's why I'm stuck with PCI
Thanks though.
Hello,
I found another possible pci card at www.newegg.com:
http://www.newegg.com/app/ViewProductDesc.asp?description=14-140-041&depa=1
Chipset: nVIDIA GeForce FX 5700LE
Memory: 128MB DDR
BUS: PCI
Ports: VGA Out(15 Pin D-Sub) + TV-Out(S-Video) + DVI
Support 3D API: DirectX 9, OpenGL 1.5
Max Resolution@32bit Color: 2048X1536@85Hz
Cable/Accessories: S-Video Cable, Drivers
Retail Box (See pics for details)
Model#: BLOODY MONSTER 5700
Item#: N82E16814140041
$89
Any good?????
Goto newegg.com and get the best PCI card you can find in budget, end of story. Their site is great for that. Select PCI from the Video Card area drop down and set a max price then hit search.
Hello,Originally Posted by Flaystus
Thanks.
That's what I did.
I'm trying to figure out what the highest generation for nvidia and ati are in that price range (near $100). I'll keep checking newegg. Thanks
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 21:45 -
PCI Graphics Card
By blueyonder in forum ComputerReplies: 20Last Post: 6th Jun 2009, 11:40 -
dvr pci card
By platonas in forum Newbie / General discussionsReplies: 2Last Post: 19th Feb 2009, 04:37 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
