I have about 7GB worth of mpg files that I want to burn to DL 8.4GB disc, I am using Pinnacle Studio 9.3 and am not burning directly to disc but creating the content only. I specify 8.4GB disc and it tells me I am 390 Mins over??? what gives, I converted the mpg files from avi using TmpgEnc and specified 1500KB bit rate. I think it is because the KB/sec in the settings for Pinnacle Studio 9.3 only go down to 3000, it will not go down to 1500... I was wondering if I am doing something wrong? I created menus for my files but that should take up but a few mbs at most.
i dont think it supports DL - looks like anyway
Just have Studio 9 make the VIDEO_TS folder, then use Nero to burn the disc.
9.3.5 support DL it has option to burn to 4.5 or 8.4 GB discs. I am burning just the TS folder i am not burning to disc, I am creating just the TS content to burn using Nero, but I change it to 8.4GB all my mpg's involved total 7GB, but it a total of 600 somthing mins, Studio then tells me I am 390 mins over!!! It seems like Studio is cacluating in mins rather than by size, I don't get it, I have 7GB worth of mpg files. I have used other crappy dvd authoring tools that can't create advanced menus like Studio and it would have no problem burning it, Like TMPGenc DVD author but that program stinks at creating menus.
what can I do? -
I gave up on Pinnacle Studio back at version 8.12
Here is their support forum for studio 9
http://webboard.pinnaclesys.com/read_forums.asp?WebboardID=1&SectionID=227&lng=1 -
it does seem to have a lot of problems ..
also -- i found a patch for DL issues
http://pinnacle.custhelp.com/cgi-bin/pinnacle.cfg/php/enduser/std_adp.php?p_faqid=10898"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Pinnacle Studio 8
By Victri in forum Newbie / General discussionsReplies: 1Last Post: 24th Dec 2007, 04:18 -
Pinnacle Studio 11
By fjmr in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 03:44 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
pinnacle studio 11
By serega in forum Latest Video NewsReplies: 14Last Post: 13th Sep 2007, 18:14 -
Is anyone using Pinnacle Studio 11 ???
By maxtrack in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 22:56
