I cut the mpg file use TMPGEnc Plus to in put to TMPGEnc DVD Author,and make a DVD Authoring, but some time it happen to has problem, it said
(the video GOP is too long) ,if I'm not cutting the file ,it will ok,
the reson I cut the file becose I want to put two different video on one DVD,is any other program can do the work?
thanks
Hi sleung,
Your best bet is to encode each video that you want separately to its own MPEG file using TMPGEnc Plus.
Then, in TMPGEnc DVD Author, add each MPEG file into its own track.
No GOP problems, and 2 videos on one disc.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
In TDA you can add each file and choose which parts of each to author. No cutting necessary beforehand.
How do I edit, cut, join DVDs, VOB, VIDEO_TS folders
By Baldrick in forum Authoring (DVD)Replies: 13Last Post: 9th Oct 2013, 06:03 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 12:04 -
Cut and Join VCD Files: tools that can Handle that
By devilcoelhodog in forum Authoring (VCD/SVCD)Replies: 5Last Post: 15th Jan 2010, 21:57 -
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 16:57
