  1. Guest
    Guest
    I can get my computer to power off in xp after a reinstallation. I've set "turn off hard disks" and "system hibernation". Is there any way to turn the computer off after a set period of inactivity?
  2. Member SquirrelDip's Avatar
    Nov 2002
    I saw this one on fileflash: Shutdown Screensaver v1.1
    Haven't used it but it's freeware...
  3. You could try here
    http://www.download.com/3120-20_4-0.html?qt=auto+shutdown+xp&tg=dl-2001
    Didn't see any free ones but there might be some in there
  4. Member SquirrelDip's Avatar
    Nov 2002
    My previous link looked good but program no longer supported... I found this one instead. Just unzip it to your system32 folder...
  5. Banned
    Sep 2004
    Inner Circle of Thought
    It would probably have to be adjusted in the bios
  6. Guest
    Guest
    sounds scary.
    Aug 2003
    NE Ohio
    sounds scary.
    Why????
    ../windows/system32 is where you screen savers go.
    There are many ways to get from point A to point B.... Here's my take:
    Try exe2scr.
    JSB
