hi,
I bought a hp 630i and after updating "its" firmware, i couldnt burn the spindle of dvd+rs I had already, (from the other hp dvdrw drive i upgraded from. ??)
So after looking on numerous forums I fouund out that my new drive is really a benq 1620. So I flashed it with the 2nd newest firmware for that benq model and it now shows up as a benq 1620 in windows and in other tests (nero, dvdinfo pro etc).
NOTE I did reflash it to the newest firmware for the benq models (b7S9).
Anyway, it DID burn a back-up dvd movie (Im using dvd xcopy express BTW) BUT the it WILL NOT read the movie, it only WROTE IT!! it just seems like theres a blank in the drive now, BUT my other dvd-rom will play it. What the heck?
But it does seem OK burning with a couple of other brands of media.
Im just nervous cause the first brand of dvd+rs I tried failed so , you know first impressions, should I switch it? The quicky media is e3works brand (I THINK its +R, not -R) and i cant any help at the other forums a or anyone who has this drive and similar issues. HELP!!
BTW, is a benq 1620 retail exactly the same as a HP 630i?
http://club.cdfreaks.com/forumdisplay.php?f=92
post your question at the BENQ FORUM, there are lots of peeps that can help you out. i just got a I/O MAGIC burner that is a rebadged BENQ drive, on the drive itself it does say BENQ 1620.
New PC advice
By garryward in forum Video ConversionReplies: 1Last Post: 29th Nov 2010, 12:27 -
New PC advice
By neworldman in forum ComputerReplies: 14Last Post: 19th Feb 2010, 09:17 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2008, 23:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 22:39 -
I need some advice
By CM World in forum MediaReplies: 1Last Post: 6th Aug 2007, 04:58
