Hi!
I Got an movie where the structur is:
VIDEO_TS.BUP
VIDEO_TS.IFO
VIDEO_TS.VOB
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_0.VOB
VTS_02_0.BUP
VTS_02_0.IFO
VTS_02_0.VOB
VTS_02_1.VOB
VTS_02_2.VOB
VTS_02_3.VOB
VTS_02_4.VOB
VTS_02_5.VOB
It starts with the meny but when I go further to next menu the DVD came out of the player!
Is there any chance to fix this?
Thanks in advance!
Regards,
V-70 -
It seems that it is pointing to wrong files somewhere!
Please help me someone?Regards,
V-70 -
did you make or author the DVD or was the DVD store purchased?
Files look fine to me as far as names and order go.
We are going to need much more information to help you here.
I am assuming this is a DVD you authored, what progs did you use, is it a movie only backup, is it a movie only keeping the original menus, did you create your own menus to add to the DVD...etc, etc. What kind of media is it burnt on? you know...some specifics. -
I'm assuming that this is downloaded, as it is quite common for the authors to leave out VOBs. What I'd do with this is rename VTS_02_1.VOB through to VTS_02_5.VOB to VTS_01_1.VOB through to VTS_01_5.VOB, then follow http://members.dodo.net.au/~jimmalenko/test.htm#ifoedit to create new IFO and BUP files for you. What this will do is make the resultant DVD play the movie automatically on insert, so if you want a menu you could look at adding the movie into TMGEnc DVD Author and create your own menu for it.
If in doubt, Google it.
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15 -
Any Programs Have Better System than Long Play, Extended Play?
By johnharlin in forum Video ConversionReplies: 3Last Post: 10th Jul 2009, 20:04 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 21:23 -
how to play mp3's randomly in folder without play lists
By deejay.2001 in forum Software PlayingReplies: 4Last Post: 22nd Apr 2008, 14:27 -
Avid Lquid 7 menus..play chapter and play all
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 02:34
