I just found out how to disable the copyright from the original DVD. I found out from "WormGuy." This is how:
WormGuy from United States reported December 14, 2004:
Comments:
*** MACROVISION COPY SOLUTION ***
I have discovered a trivial workaround for the inability of later-made LVM-5005 machines to record a macrovision (MV)-encoded signal.
1. On the LVM-5005, start recording from a source that does not contain MV. A blue screen or the splash screen of your DVD player will work fine.
2. Just after the recording has started, press <pause>.
3. Start the source that contains MV. For a DVD movie, this would mean loading a disc, navigating through the menu and and starting the movie. For a VHS tape, this would mean starting it playing.
4. Press <pause> again to resume recording.
Have fun!
WormGuy
I tried this method and it actually worked! This is the other way to go around it.
I don't know if it works only for my DVD recorder, LVW 5005, but i think it works for any DVD recorder.
Enjoy.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Closed Thread
Results 1 to 24 of 24
I doubt it. Like most MV checks, it rechecks the signal periodically, not only at the beginning.
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS
Sounds like LiteOn is using a weaker check.
But who copies DVDs this way? I would be feeding it VHS source !!!
Keep in mind that the non-TBC filter-type clarifiers and stabilizers not only remove the MV signal, but also usually degrade part of the video because they are filters, and aren't perfect Only a TBC will remove copy protection without changing the video itself
Originally Posted by sync
I tried a few disney films that my wife wanted to transfer to dvd and i did the macrovision trick. It recorded for approximatly 10 minutes then said 'Copy Protected' and then stopped... The macrovision is checked every few minutes and so this way does not work on most of the stuff i have tried....
Originally Posted by hustler1968
You are in breach of the forum rules and are being issued with a formal warning. Copying your rentals is a no-no.
/ Moderator lordsmurf
What I've Learned so Far-LiteOn 5005
By RiteOn in forum DVD & Blu-ray RecordersReplies: 27Last Post: 14th Oct 2012, 20:58 -
Liteon LVW-5101
By vmelkon in forum DVD & Blu-ray RecordersReplies: 2Last Post: 18th Feb 2011, 15:28 -
Liteon LVW-5005 cant prepare 16 X DVD-R before recording
By coody in forum DVD & Blu-ray RecordersReplies: 24Last Post: 8th Jun 2009, 14:54 -
LiteOn LVW-5005 timer recording fails?
By bevills1 in forum DVD & Blu-ray RecordersReplies: 15Last Post: 13th Jun 2008, 09:37 -
LiteON 5005 weirdness
By kenmo in forum DVD & Blu-ray RecordersReplies: 53Last Post: 2nd Jun 2008, 11:05
