Results 1 to 12 of 12
    Sep 2001
    Canada
    hey everybody,
    I've been at the svcd game for years now but have recently acquired a dvd burner, so I'm looking to convert to dvd. I have a video in two parts with ac3 audio, and I was wondering, is there a way to join the ac3 audio from both parts into one? I can join the video parts but I'm unsure how to do the audio without decoding to a 2 channel wave and using an audio editor. Basically, I just want to burn to dvd in one file instead of two separate parts while still retaining the ac3 sound if possible. Hopefully somebody has some idea how to do this and any help would be greatly appreciated.
    Thanks,
    407
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    in a cmd window
    copy file1.ac3+file2.ac3 newfile.ac3 /B
    Sep 2001
    Canada
    That only seemed to leave me with an 856 byte file. Is there another way to do this?
    407
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    try copy /B file1.ac3+file2.ac3 newfile.ac3
    it will work one way or the other
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    make sure you specify the location also ... if ac3 not in path
    if you put the ac3 files in your path - no problem
    (like put them in root of c for example )
    Sep 2001
    Canada
    Beautiful! thanks, now I just have to try to find a way to normalize the ac3 while still retaining the 5 channels...any suggestions?
    407
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    you have to re-encode then ... not good ...
    Sep 2001
    Canada
    Maybe it's not worth the fight...
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    that means -- convert to wav , normalize , convert to ac3
    and not normalze all chanels the same as the levels WOULD/SHOULD most likely be diff.
    Sep 2001
    Canada
    what channel is normally the loudest? I was thinking about decoding all channels, normalizing the loudest channel and using the same normalizing factor for the others. Would that work to get all channels up to the same relative level to eachother as before, but at a higher overall volume?
    407
  11. Член BJ_M's Avatar
    Jul 2002
    Canada
    i would to suggest not doing that -- why do you want to increse the volume ?
    if you want to increase the overall volume - turn up the volume OR change the compression settings when re-encoding .... dont change the channel balance
    Jun 2004
    Ferrara-Italia
    I too would compress the dynamic range if the dialogues are too low for your taste. Normalizing channels on their own is not a good idea
    Sorry, I had to go see about a girl
