  1. I used DVD Shrink 3.2 to create the files. I then used Roxio platinum to do the burn.
    I can play the DVD in my computer, but not my Sony DVD player.
    What did I do wrong? Or am I using the wrong software?
    Thanks.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Have you tried another brand of discs yet????
    https://www.videohelp.com/dvdplayers
    Put your model number in the above link and make sure it plays your type of media/format.
    Kevin
  3. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Is it possible you burned the disc as a DVD-ROM instead of a DVD-Video?
