Results 1 to 15 of 15
  1. Hello:
    I used DVD Shrink 3.0 to compress a DVD9 to DVD5 and then got the DVD Decoder to record to my DVD +RW. Everything worked fine except it took 4 hrs to complete the "shrink" operation and 7 hrs to finish copying to the DVD disc. Is that because of the way I did or of the speed of my burner? I am using Sony DRX510UL DVD burner and Memorex 4X DVD+RW. Please advise.
    TITEO
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Make sure the burner is in dma mode.
    Get a newer version of dvdshrink.
    It is now up to 3.2
    I also recommend using dvddecrypter to rip the disc.
    Jun 2004
    USA
    If your profile is correct then I think your computer may need to be upgraded significantly in order to speed the process up. What you are trying to do is CPU and memory intensive.
    wwjd
  4. Banned
    Sep 2004
    wwjd
    Yep
    I would add more ram to say the least.
    A larger hard drive also would help.
    Your CPU is too slow. That is about right for 400mhz
  6. Thanks, all. Look like you you answer my question. My CPU is 400MHz; so how fast should you guys recommend me to upgrade to?
    TITEO
  7. Banned
    Sep 2004
    You could do it with an 800 MHz processor, but the faster the processor, the less time it takes.
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Yep I had dvdshrink on a 800mhz amd and it would take up to 30mins to rip and transcode at the same time (without deep analysis - and movie only in reauthor mode).
    Also a faster dvd rom drive might help
    Kevin
    2-3ghz
  10. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Originally Posted by titeo
    ... so how fast should you guys recommend me to upgrade to?
    As fast as you can afford.
    Apr 2003
    Largo, FL
    If he's going to spend money on a new processor I'd say get at least 1.2 GHz, and even 2.0 wouldn't be that much more.
  12. Thanks all. I have to dig into my budget after all. Well hope that I won't be broke after all those upgrades.
    Thanks again and Merry Christmas to all.
    TITEO
  13. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    I think you'll thank yourself later. 400 MHz is below the recommended minimum for any hardware capturing work, and encoding a large DV to MPEG would probably take you more than 24 hours
    Decent machines or MB/CPU combos in the 2 - 3 GHz range aren't that expensive anymore.
    On my 3ghz w/ 1gb DDR400 ram it takes about 12-13 minutes with default settings. Very niice. I haven't tried the deep analysis and other enhancements, i'm sure they would be signifigantly longer. I believe to even get a 1:1 encoding time you'll need greater than 2ghz. anyone may correct me on this if i'm wrong.
  15. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I'd look at upgrading CPU, RAM and Hard Drive. More than likely you'll be looking at a new mobo as well, so I reckon you might as well just get a whole new box, and keep your existing monitor. You won't know yourself if you get onto something with a CPU in the 2-3GHz range & 512MB RAM or thereabouts.
    If in doubt, Google it.
