what is the best ? I've used both of them, and honestly, don't see any difference.
tried to search on the net any topic related to this, but no luck
people say that 1.5 is better than 2.0
Results 1 to 10 of 10
well since you bought both -- use either one if you see no difference ..
i did a comparison a while back on this forum .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Why did you buy both, without checking out the functionality of the earlier/later version?......try and get a refund on the version you dont like.
who said I bought them ?!
I just need some opinions from peolpe who used both.
Before anybody jumps up and down yelling 'warez' ... realize some of us have friends that have computers that do video too. It's how I get all my Mac experience, for example.Originally Posted by lenti_75
8)Want my help? Ask here! (not via PM!)
I didn't say anything -- same with me and FinaL Cut Pro and a lot of other apps owned by company(s) ..
I had just assumed the way the first post was worded that he had both in hand .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I wasn't posting specifically to anybody.
I just asked a simple question....but it went into a wrong direction, if you own or not the software.....
NOW, does anybody did some more testing ? I need more "heads" on this.... -
did you look at the comparison ?
1.5 seems a little better with some material , 2 with others
2 has a lot more features and is MUCH faster .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I can't really "see" the difference between 1.5 and 2... Feature wise though, 2 is way above 1.5.... I really like the direct to dvd compliant VOB conversion. I also can't remember but I belive some of the filters like the very powerful "temporal noise reduction" are not in 1.5...The queing and watching utilities are also vastly improved...
Procoder SVCD
By kippard in forum Authoring (VCD/SVCD)Replies: 7Last Post: 17th Dec 2008, 10:51 -
Canopus Procoder Help
By spliffy in forum Video ConversionReplies: 3Last Post: 15th Nov 2008, 03:07 -
Canopus Procoder Cropping
By spliffy in forum EditingReplies: 1Last Post: 20th Dec 2007, 21:25 -
chapters with procoder 3
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 17th Oct 2007, 11:20 -
Anybody tried Canopus ProCoder 3?
By cosmin in forum Video ConversionReplies: 1Last Post: 16th Oct 2007, 21:25
