If you have a Pixma 3000 and above and bought it in the USA, you may want to check out this forum. As you might have known, the non-USA version of this printer can print on CDs, but not the USA version. Well, AlvinLee describes a method to overcome this limitation. If anyof you try this, could post back here with your results. I currently don't have any printable disks, but plan to get some as soon as the road thaws out.
http://www.stevesforums.com/forums/view_topic.php?id=36631&forum_id=40&jump_to=214717#p214717
I just bought a Pixma 5000 printer and I have been following that other thread with interest. It started out as a discussion on how to get the CD tray, software, and firmware if necessary, to defeat the Canon's disabling of CD/DVD printing in the US.
Then Alvin Lee came up with a "simple" way of printing them without the need for any of that other stuff.
A few people have tried it and say it works. Now I need to get myself some printable media so I can try it for myself.
Can you post back after you give it a try. I usually buy my ink from databazaar and get genuine Canon. They now carry generic ink, I wonder if any of you have had any experience with it.
www.databazaar.com
Also, the BCI6 and BCI3 are listed as compatible, along with photo ink. I thought only the BCI6 YMC was used for this printer. Will the others work? Better?
Finnally, I wonder about the ink smearing. I know many people use the R200 to print to CD, but the Epson ink is designed not to smear. How is canon ink?
Convert Epson CD Print ec3 to Canon's CD-LabelPrint ?
By Ripper64 in forum MediaReplies: 39Last Post: 1st Oct 2014, 22:26 -
Printer tray for Canon Pixma
By Yenny in forum MediaReplies: 16Last Post: 27th Feb 2010, 18:33 -
Which Canon printer should I get to print on dvds?
By zanos in forum MediaReplies: 7Last Post: 4th Sep 2009, 19:58 -
Canon Pixma IP4500 - Printing DVD Tops, colours not "right". Thou
By phase52001 in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2009, 23:32 -
Canon CD Lable Print
By chesterfield in forum MediaReplies: 3Last Post: 17th Jun 2007, 22:43
