Has anybody had an experience using a Serial ATA to IDE Adapter with their Pioneer DVR-108? Will it work, will I lose or gain performance or is it not recommended. The one I would like to purchase is at http://www.pcimicro.com/.sc/ms/dd/1103465331339601/976662/nc/ee/2504/1755768
Thanks.
Kizer
Results 1 to 11 of 11
I've moved you to the Computer Forum.
What's the situation? For what that converter cost you can get an IDE controller card and just tap it into that.
FB-DIMM are the real cause of global warming -
It should work, as long as it can use PIO mode (PC33 or PC66) that slower devices such as DVD/CD drives use. For the price, I would give it a try.
Another thing to consider, (i'm not sure how important it is), about such converters is that they may block the cooling vents at the back of your drive.
Back of Pioneer DVR-108
Syba ATA adapter installed
I just plugged mine into an IDE port. I think it's even a slave device. I wouldn't have thought there is any performance improvement to be had by using a SATA port for this device as it's max transfer speed is 66.6mb/s.
Regards,
Lee. -
Thanks for all your replies. My problem is I am out of IDE channels. I am adding a Pioneer to my system with 2 IDE Hard Drives and 1 IDE DVD reader and 1 IDE Sony DVD Burner. I also have 1 SATA Hard Drive. I decided to move my Sony DVD Burner to SATA with the converter and put the Pioneer in its place on IDE. Hopefully it won't block the Sony's vent.
Thanks.
Kizer -
YOu could also buy a separate PCI card that'd give you extra IDE channels. They're cheapOriginally Posted by kizer8
You need some more coffee CapOriginally Posted by rallynavvie
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 09:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
