  1. hi
    Is it possible to copy dvd + to a dvd - disk from the pc, if so is it just a matter of copying from the 2 drives or do u have to use a softwre program, if so which one?
    many thank
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes. Most DVD capable burners ought to be able to do it, even if I suggest doing it in two steps - read to image -> write image. For the latter approach, use DVDDecrypter. (And of course software is needed - everything a computer does is governed by software!)
    /Mats
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Yep if you can read it you can copy it (yes is the answer ).
    Kevin
  4. Banned
    Sep 2004
    Inner Circle of Thought
    Yes
    Jul 2003
    michigan
    oui
    member since 1843
