Results 1 to 19 of 19
  1. I have a question is there any way to encode (Author) a film using two computers with Windows Xp operating system ??
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Why????
    What are you trying to do???
    Kevin
    PS - what is your setup and what is your target destination?? DVD or xvid/divx???? Some more info please
  3. Generally I want to convert .avi to DVD with my two computers but any other operation like only .avi to MPG conversion without Authoring will be interesting.
  4. develop thoroughly.
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Are you referring to "batch encoding"???? If so you can do it on one computer.
    Other than that your question is still vague. There are plenty of guides in the "how to" section on the left of the screen <-------
    Kevin
  6. Problem is, encoding and authoring are 2 different/distinct operations. What do you want to do. Providing an example might be the best way for us to understand what you clearly.
    Jan 2004
    PAL Region
    I get the feeling this is another 'Can I make a rendering farm out of all my computers so I can encode in a couple of minutes?' sort of question.
    If so, then the answer is no, at least to my knowledge. The only software capable of this in the graphics world are CG packages.
  8. I want to do one operation on 2 computers in one time (not batch encoding). I know that encoding and authoring are 2 different operations but I don't know what can be done in that way only encoding or whole encoding and authoring operation.
    Example:
    I have 1.avi and I run program A on computer X and on computer Y I set up settings and run - programs on compures X & Y are sharing operations (they comunicate each other). X can do one thing and Y another - in this way encoding (or whole jov avi-> DVD) should be done quicker - but this is only idea and I search for program A
    Jan 2004
    PAL Region
    Render farm, then...
    Refer to my previous answer. It still happens to be no.
  10. Член BJ_M's Avatar
    Jul 2002
    Canada
    not for mpeg encoding --
    but there are many video programs that will render video on more than one (render farm approach)
    like :
    Sony Vegas, Shake and Fusion
  11. Член BJ_M's Avatar
    Jul 2002
    Canada
    not really true -- see above ..
    Jan 2004
    PAL Region
    like :
    Or maybe I was wrong....
    I never use these for encoding.
  13. Член BJ_M's Avatar
    Jul 2002
    Canada
    because of the B frames in mpeg files - it is harder to do renderfarm wise - though with closed GOPS , it is possable ....
  14. Член BJ_M's Avatar
    Jul 2002
    Canada
    i forgot After Effects .. it also works encoding on a renderfarm ..
    some use macs to work with after effects and render on pc's on a render farm ..
    Jan 2004
    PAL Region
    We appear to be hitting submit at exactly the same time.
    If it was really a viable thing to build a render farm (probably not correct terminology but what the hell...) then we'd all be doing it and we'd all know about it to answer the question. That's what I was basing my answer on.
  16. Thanks for help.
    BTW. I heared from another source that Adobe Video Collection Professional 2.5 can do it.
  17. Член BJ_M's Avatar
    Jul 2002
    Canada
    only 'after effects' .. from adobe (part of the package)
  18. Член BJ_M's Avatar
    Jul 2002
    Canada
    and that is not to mpeg2
  19. Член BJ_M's Avatar
    Jul 2002
    Canada
    plus the cost can get expensive (the lic's + the hardware)
