I ripped a DVD to Divx with AC3 fine. Now I want to re-encode the divx file to a different size but Dr Divx wants to convert the audio to MP3 and I cannot find a way to retain the AC3 audio. Please Help!!!
use the dvd as your source. Re-encoding the already-compressed mpeg-4 back-up is not a good idea if you have a better source to start from.
Second: use virtualdubmod, set audio to direct stream copy and encode only the video stream.Sorry, I had to go see about a girl -
This is what I have been doing...using Vitual Dub...but am also trying to convert existing Xvid files using Dr Divx and retaining the AC3 as Dr Divx does a much cleaner job of it than Vdub...
Convert to a new divx using dr. divx, you can select no audio if posssible if not just use audio.
Then use virtualdubmod to add the ac3 from the old divx,
Open the old divx and stream->stream list and demux to get the ac3
Open the new divx, select video->direct stream copy and the video wont be reconverted. Add the ac3 audio under stream->stream list add.
Save as a new divx. -
Gotcha.....was just making sure I was not missing something within the DR that could handle it all for me....but thanks for the advice...
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Mts to DVD/MPEG2 retaining 5.1 Audio
By mukeshs in forum Video ConversionReplies: 0Last Post: 18th Feb 2010, 14:46 -
Creating a DVD from a MKV file and retaining all the audio tracks
By TioSolid in forum Video ConversionReplies: 7Last Post: 8th Aug 2008, 08:06 -
MKV to Divx while retaining 5.1 sound
By artisticcheese in forum Video ConversionReplies: 7Last Post: 28th Jun 2007, 15:42 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 16:51
