    May 2003
    Oz
    I've encoded two videos and then authored them both to one DVD (first time I've tried more than video to a single DVD) with DVD-lab PRO and that all went smoothly as I did it just exactly the same way as I've had success before doing the videos one at a time.
    When I go to burn it though I get this error message from Nero I've never seen before. What does it mean and what has caused it?
    May 2003
    Oz
    Would somebody please be kind enough to point me in the direction of a guide which shows how to add multiple movies to one DVD authoring project with DVD-lab PRO?
    I've tried looking for one both here and on the dev's site but can't find anything. It must be possible and indeed when I try it by doing the obvious, I don't get any warnings or errors except when I go to burn the end result with Nero.
    My videos are the same resolution, aspect ratio and even bitrate so I dunno what's going on. I need a guide to follow. Can anyone help please?
    May 2003
    Oz
    Just by way of supplying some kind of resolution to this thread, I would like to report that the error being reported by Nero is after creating a DVD compile using DVD-lab PRO v1.00 build 041025. This release would appear to be buggy because since reverting back to v1.00 build 041014 again, this problem is no longer an issue.
    Moral of the story: don't use DVD-lab PRO v1.00 build 041025
