    Apr 2004
    Minneapolis
    i have a vcd mpeg1. When i try to author with it in TDA, it says only mpeg1/2. I have many like it and have no problems.
    So i tried tmpgenc plus to re encode again, which the file is also denied. I tried to deplux and that too was denied. All the specs are compliant, why is it being denied by tda and tmpgenc plus?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Can you post a screenshot of the error you get ?
    Also the specs of the MPEG file ?
    If in doubt, Google it.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Avicodec will give you the specs.
