  1. Banned
    Dec 2003
    USA
    everytime I have to print a dvd I have to go in to the settings and then click on my settings i saved to print or it i don't it is on standard defalt (text/no good detal). How to i make my r200 go to thoes setting my defalt? Let me know thanks.,
    Also what settings do you have on your r200 r300?
  2. Member joecav's Avatar
    Philadelphia, PA USA
    I would also like to see what people use as settings, I am a new R200 owner and lovin it!
  3. Open the R200 printer on your system and then go to Printing Preferences. Go to advanced settings, setup what you want the printer to do. In the lower left hand corner is a "Custom" setup and SAVE SETTINGS button. Name the setup what you want and click to save settings. When it opens, it will default to what you have setup. If you change your mind later, just click the reset defaults button and everything is back as was. At least mine does and I assume your's will too.
