My Pioneer DVR-320 seems to be capturing (DVD-VR mode) at 544x480 resolution at the 2hr 10min recording time level. TMPGEnc DVD author is complaining that the resolution isn't DVD complient. What's the deal? Do I really need to re-encode it? That's kind of a pain in the ass... Should I try again in DVD-Video mode? Will that solve the problem?
Thanks!
I have recorded to 544x480 Rez alot.
I use DVDPatcher to fool TMPGEnc DVD author into thinking
it has a DVD compliant vid.
(I patch them to 720x480 Rez.)
Just don`t forget to repatch back to 544x480 the resultant Mpeg2 movie files
(within the TMPGEnc DVD author generated VOB files)
It may take a little experimenting with your 544x480 Rez vids, but
I know it works.
Happy Holidays and Good Luck!
Sometimes ... when you cry ... no one sees your tears...
Sometimes ... when you are worried ... no one sees your pain...
Sometimes ... when you are happy ... no one sees your smile...
But fart just one damn time ... -
VR mode is not DVD-Video compliant.
Use DVD-VIDEO or VIDEO MODE onlyWant my help? Ask here! (not via PM!)
vico1, if I patch the files and fool TMPGEnc DVD Author, will some standalone dvd players have problems playing the video? If so, I'd rather just re-record in DVD-Video mode (which seems like it should record with a compliant res).
Yes, patching will be equally as problematic.
DVD-Video is compliant, and is the best choice.Want my help? Ask here! (not via PM!)
