what do u guys think the best transcoder is for picture quality? i dont care about the speed or if its free or not. thanks.
Everyone has a different pick and it is really hard in my opinion to pick one as "the best".
Having said that I always preferred DVD2ONE myself.
Lately I have been using DVDShrink (it is free) because my computer crashed and I lost my serial number for DVD2ONE and haven't felt like paying another $40 some odd dollars for it again.
But I kinda miss it
But since DVDShrink is free you might as well give it a try.
I should point out that a lot of people are also very found of CloneDVD2 but again you must pay for it. It does has have a trail period though. I just downloaded it to a new computer and tried it and it seemed to work really well but my compression was only 87% which is a low amount of compression so that might not have been the best test.
One thing I don't like about CloneDVD2 though is that there is no option I could find to adjust the final output size. So it ended up being 4460MB which is DAMN close to the limit of a DVD. With DVDShrink and DVD2ONE you can adjust that and I normally went for 4400MB so as not to "cut it" so close to the bone. It could be such an option exists and I just missed it but I looked everywhere for such an option with no luck. Of course I read no docs or guides for it hehehe
What do you think About CloneDVD2 ?Originally Posted by NYPlayer
Have you used it much?
Clonedvd2 is my transcoder of choice.... also has the best burn engine I have used. I use it about %95 of the time to transcode.. %100 of the time to burn DVD Files.
Imho, CloneDVD2 rates right up there with DVDShrink/Recode.(same author)Originally Posted by FulciLives
Truth is, having used them all a lot, I got excellent results with all three.
Sometimes ... when you cry ... no one sees your tears...
Sometimes ... when you are worried ... no one sees your pain...
Sometimes ... when you are happy ... no one sees your smile...
But fart just one damn time ... -
Fulci, I wouldn't want to suggest anything in violation of forum rules, but I did hear of one program called Nagbuster that was designed for situations like yours with DVD2ONE.
Having said that, I use DVDShrink and DVDDecrypter all the time. I have never had a real problem with them, so if it ain't broke...
Actually, what I would like in the next version of DVDShrink is the ability to retain layer change positions, or place layer changes, in order to increase the likelihood of the resultant DVD working properly."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Real time ac3+ transcoder?
By andyhuk in forum AudioReplies: 1Last Post: 13th Jul 2011, 23:14 -
Looking for Video Transcoder
By Ankit in forum Newbie / General discussionsReplies: 1Last Post: 30th Sep 2010, 04:27 -
Anyone ever use a transcoder on DVD-Rebuilder output?
By sldvd in forum EditingReplies: 2Last Post: 20th May 2010, 14:16 -
Kramer Composite-YC Transcoder
By wiseant in forum RestorationReplies: 2Last Post: 6th Feb 2010, 01:12 -
Quality-loss due to transcoder?
By joelson in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 16:28
