    Mar 2004
    I've been playing with mmc 9 and have had a couple of caps that resulted in a very slight audio delay (it seems a fraction of a second behind). Is there an easy way to shift the audio in a multiplexed stream or do you have to de-plex and trim a tad off the front?
    what's your method for correcting audio sync issues?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
