I needed to cut a clip I got recently but none of my tools seem to work so I thought I'd encode to Divx or Mpeg and cut it then. Any free tools to do this? Thanks.
No need to encode to DivX. DivX = MPEG4, so all you have to do is extract the video, then change the fourCC from mp4v to DIVX/DX50.
it is QT mpeg4, not avi ....
any NLE will edit QT"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Using AVS2DVD to convert mp4 to DVD - I may have run into a problem
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 14th Apr 2011, 21:43 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53 -
Can QuickTime Pro Convert XDCAM MP4 to .mov?
By boriega in forum Video ConversionReplies: 2Last Post: 15th Sep 2010, 16:17 -
MKV with Variable Framerate convert to MP4 problem
By beaniekapp in forum Video ConversionReplies: 12Last Post: 4th Jul 2010, 09:44 -
QuickTime Codec for WinAVI MP4 Converter
By neumannu47 in forum Video ConversionReplies: 4Last Post: 6th Sep 2008, 10:41
