i have a divx avi files that i am trying to encode with tmpegnc. when i play this file i have no problems , but when i try to encode it ,about 9 min. into it it keeps on giving me an error message. any info on how i can fix this.......
Load the DivX AVI into VirtualDubMod and then frameserve to TMPGEnc Plus.
Doing so will slow down the encoding time somewhat but for some reason this "trick" will often work (full encode) whereas loading the file directly into TMGPEnc Plus causes a crash.
If you are lucky it will be that simple.
It could be that the DivX AVI has "bad frames" or some other problems that frameserving cannot "hide" from TMPGEnc Plus.
What type of audo does this DviX AVI file use? Most often it is MP3 audio. In that case you want to separate the audio and process it separately from the video.
If you have MP3 audio the best thing is to open the AVI into a sound editing program such as GoldWave or Soundforge. Once you do that you can save it as a 48k 16-bit Stereo PCM WAV audio file. Then you can convert that to AC-3 or MP2 or whatever you want on the DVD (you can even use the PCM WAV file although that takes up a HUGE amount of space).
avi.Net Problem: Not producing an .avi file
By Johnathan K in forum Newbie / General discussionsReplies: 10Last Post: 5th Feb 2011, 16:22 -
Replacement for TMPEGnc DVD Author for the Mac?
By The Monkees in forum MacReplies: 1Last Post: 24th Feb 2009, 14:36 -
AVI File Not Supported by TMPEGnc?
By The Monkees in forum Video ConversionReplies: 5Last Post: 3rd Feb 2008, 19:26 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
