  1. I am trying to get a divx avi to play smoothly on my divx dvd player. I have heard that unpacking the bitstreams can help.
    I am using mpeg4modifier to try and do this - but whe I load in the file I get this error message:
    Does anyone know what this means and how it can be fixed?
    I also tried DivFix but it said there were no errors, I also rebuilt the index to no avail.
    Dec 2004
    Australia
    Is it two parts joined? For now I would suggest that you try the previous version of mpeg4modifier. New version when it is out may also work.
  3. Thankyou for the help.
    I tried v 1.1.0 and it worked fine, the divx played much better on my dvd player after unpacking the bitstreams.
    Tho now it doesn't play very well on my computer - its really jerky!
    Lol one or the other!
    Dec 2004
    Australia
    That is because you left the DivX packed bitstream tag. Removie it and it should play fine on both.
  5. Genius
    Thanks - I read somewhere that you should change it from "p" to a "n".
    Did that and it seems to work.
    Thanks a lot
    Dec 2004
    Australia
    I would just remove it. When XviD itself encodes with bfames and no packed bitstream it only adds the bitstream version flag.
