I got a new computer so I downloaded all my programs I had on the last one. I burned a DVD chapter and when I load the vob file it says the file is unsupported or something like that. isn't there a plug-in to ad, so this doesn't happen?
You would be better off ripping the DVD in FILE MODE (SELECT ALL FILES) with DVD Decrypter then creating a D2V project file with DVD2AVI
TMPGEnc should open the D2V file directly without issues.
Another benefit of this is that you can use the D2V project file in an AviSynth script. Some people are scared of AviSynth scripting but it really is not that hard once you get used to it and allows you to control a lot of stuff including the use of one of the best all around "video noise filters" known as Convolution3D.
You can use AviSynth scripts with TMPGEnc but once you master AviSynth you can then start using CCE BASIC which works better than TMPGEnc and is much faster.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
What is the different between TMPGEnc Authoring Works 4 & TMPGEnc 4.0 XPres
By c1steady in forum Newbie / General discussionsReplies: 0Last Post: 28th Apr 2010, 21:32 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
