I've been having this one annoying problem with my LCD monitor. When my computer is not in use, I turn off the monitor. If I don't turn off the monitor and it's been idle for about 30 minutes, then the screen automatically turns black and then the light on the monitor will turn from green to orange. The desktop will appear whenever you wiggle the mouse.
Whenever I turn off the monitor when it is already black (when the light is orange) and then turn it on again several hours later, I get this error on my monitor "No Signal". The wires and cables are all connected properly, none of them are loose. No matter how much I wiggle my mouse, the desktop won't come back. The hard drive's light is on. When I try to click the restart button, it doesn't respond. So I had to turn off the power adapter and turn it back on, then turn on the computer.![]()
How do I avoid it doing that? It gets very annoying. If this matters, I use Windows 2000.
Go into Power Options under Control Panel and you'll see your answer...
There's nothing wrong. Here are my settings:
Power Scheme: Home/Office Desk
Turn Off Monitor: After 20 min.
Turn Off Hard Disks: Never
That's all the options that are checked.
It doesn't sound like a problem with your monitor.
Sounds like a problem in the PC. Did (or does) it happen with a different monitor? Does it happen every time, or only some of the time?Ethernet (n): something used to catch the etherbunny -
TURN OFF MONITOR: after 20 minutes....is the problem.
have it set to NEVER....then you can turn your monitor off and on without any problems.....i have all my pc's set to NEVER for TURN OFF MONITOR. -
Could be, but in my case, but my second PC is set to shut off the LCD after a half hour, and it always comes back up when I wiggle the mouse, even after an hour or more. Maybe different PC's react differently to this setting?
But, it's a good suggestion, and might cure his problem. Who knows?
I only have one LCD monitor for one computer and it's a hassle to take it out since the cords and cables are facing a wall and then covered by furniture.
I'll try that I guess.
And no, it only happens sometimes.
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 12th Feb 2009, 23:01 -
LCD Monitor Problem
By Soopafresh in forum ComputerReplies: 8Last Post: 27th Apr 2008, 03:11 -
Weird Toshiba HD-A2 problem on a standard PC LCD monitor
By danimal99 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 9th Nov 2007, 12:07 -
Displaying Photos on an LCD Monitor or LCD TV
By jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 12:29 -
LCD Monitor...is it a problem?
By ron spencer in forum ComputerReplies: 6Last Post: 24th Sep 2007, 07:24
