Was wondering if anyone here had one of these printers and could help me with printing on to discs.
The problem i'm having is i want to be able to print right up to the center circle (21mm inner size). The program that came with the printer (CD-LabelPrint) allows as close as 17mm inner size. It is automatically set at 43mm inner size but only allows a 10mm +or- adjustment meaning i can only get it to 33mm inner size.
You can changes it ! b4 I got confuse, now I have done it... You can changes the inner circles 17mm.Originally Posted by deck
when you load the CDR Label up go to Files ---> select papers ----> click on Edit tab at the bottom line
Now you can adjust the inner circles and save it under new name... -
Yep thats it thanks. I knew there had to be someway to do it as it didn't make sense otherwise.
Epson R220 problem printing on discs
By nwo in forum MediaReplies: 3Last Post: 2nd Jun 2011, 13:15 -
Canon Pixma IP4500 - Printing DVD Tops, colours not "right". Thou
By phase52001 in forum Newbie / General discussionsReplies: 1Last Post: 14th Aug 2009, 22:32 -
Printing problem
By CSULB71 in forum ComputerReplies: 41Last Post: 11th Jun 2009, 20:06 -
Problem Printing DVD Case Insert
By boofer in forum MediaReplies: 7Last Post: 30th Jan 2009, 22:41 -
Canon ip4300 vs Epson 260 for printing dvds
By ultraman36 in forum MediaReplies: 0Last Post: 13th Jul 2007, 14:03
