Question: With all the new rage being DVD burners for your
PC..can you in fact rip a DVD at very high quality and then
burn it on a DVD+RW and play it back in a "regular" DVD player? I say +RW, because from my reading they are compatible with more players. I'm aware that it is cost prohibitive at this point.
Well yes & no...if your source dvd is bigger than 4.7 GB, then you can not do a full backup...you will either have to leave out some of the extras, or re-encode the movie video to a lower bitrate....less than 4.7 GB, yes you can do a complete backup...
now my question, what does this have to do with the topic of burning VCD on them??...you can not author a DVD-R or DVD+Rw in VCD format..only in DVD format. -
Actually, DVD specifications allow for MPEG1 and the VCD resolution...so in a technical sense you can put VCD video on a DVD.
yes you can put vcd mpeg1 files on a dvd but as DVD only allows 48 khz audio you might have to convert only the vcd audio to 48 khz(kinda easy with tmpgenc,toolame) as most dvd authoring/burning apps requires it.
I have succefully made such dvds with some captured star trek episodes using spruceup and sonic dvdit pe. And you will fit about 435 minutes mpeg1 vcd on one dvd.
Plextor DVD Burners?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 12th Jan 2012, 18:01 -
How to Record using 3 External Burners plus 2 Internal Burners with Speed
By mn072065 in forum DVD & Blu-ray WritersReplies: 2Last Post: 11th May 2011, 19:27 -
HD DVD Burners
By leebo in forum DVD & Blu-ray WritersReplies: 5Last Post: 22nd Feb 2008, 22:53 -
Which of the FOUR internal DVD burners is best ?
By MacPCConsultants in forum DVD & Blu-ray WritersReplies: 40Last Post: 29th Nov 2007, 22:56 -
External DVD Burners
By offensekilla in forum DVD & Blu-ray WritersReplies: 9Last Post: 12th May 2007, 16:18
