    Jan 2004
    huntersvile, nc
    hey guys,
    does anyone know of a site that will give me the registry values/hacks to decrease the amount of time it takes for xp to shutdown?
    thanks,
    schunn99
    USA
    Here are 3 sites:
    http://www.pcstats.com/articleview.cfm?articleID=1590
    http://www.windowsxpatoz.com/cgi-bin/performance/index.cgi
    http://reviews.cnet.com/4520-10165_7-5554402-1.html
    You will back up your registry before you try any of these? My machines shut down quickly enough so I haven't tried these. You may have to read through the pages to find what you are looking for. You realize hacking your registry is risky?
    Jan 2004
    huntersvile, nc
    yes, I know it is risky but it is the only way to get certain things to work the way you want them to. I backup a copy of registry any time I alter registry in any way.
  4. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    I always thought XP shut down pretty quick. It's other apps that would cause it to stall when shutting down.
    FB-DIMM are the real cause of global warming
    Aug 2003
    NE Ohio
    If you are in the " If it aint broken then teak it" mood try :
    http://www.kellys-korner-xp.com/xp.htm
    This Page has over 700 tweaks/fixes.
    Enjoy,
    JSB
  6. Member Soopafresh's Avatar
    Jan 2004
    RDILLY is the simplest Registry backup app ever. Good stuff.
    http://www.joejoesoft.com/rd.php
  7. Member d_unbeliever's Avatar
    Apr 2004
    Behind BARS
    hacking the Net using typewriter :D
